Har börjat kolla på W140 S-klass. Undrar om en W140 300 SE/S 280 levererad 12-dec 1995, såld som 1996, med nya ac'n har den gamla eller den nya kabelstammar? (De gamla menar jag dom som spricker sönder)
VIN WDB1400282A302550
Model 300 SE 2.8 / S 280
Chassis 1400282A302550
Engine 104944 22 014918
Transmission 722505 04 228796
Order 0 5 751 10062
Lights BOSCH
Cab 00000
Delivery date 12.12.95
Dealer Barbados (751)
Interior leather mushroom (265)
Paint
702 smoke silver metallic (с 01.01.1983)
Options
227 ashtray and cigar lighter in the rear, illuminated (с 01.03.1980)
220 parking aid (с 01.10.1993)
223 rear seat backrest and headrests, electrically adjustable (с 01.07.1991)
249 automatically dipping inside rear view mirror (с 01.06.1990)
241 left front seat electrically adjustable with memory feature. only applicable to w 210 when installed in conjunction with code 275. (с 01.03.1983)
242 right front seat electrically adjustable with memory feature. only applicable to series w 210 when installed in conjunction with code 275. (с 01.03.1983)
247 electric seat adjustment (front passenger seat) - additionally adjustable from the rear. (с 01.10.1989)
289 wooden/leather steering wheel (dia. 390 mm)
wood-/leather steering wheel (ш 390mm) and leather gearshift (с 01.02.1993)
multiple contour backrest for right rear single seat
308 cooling compartment in center rear backrest (с 01.01.1990)
302 folding armrest in the rear with storage tray (с 01.01.1990)
303 front folding armrest with tray (с 01.01.1990)
306 activated charcoal filter (odor filter) (с 01.01.1990)
341 additional lamp (с 01.09.1982)
425 5-speed automatic transmission (с 01.02.1988)
441 steering column, electrically adjustable, W202 manually adjustable (с 01.07.1984)
481 undershields (с 01.10.1962)
501 outside mirrors le/ri with memory (с 01.10.1994)
524 paintcoat preservation (с 01.01.1964)
533 front and rear speakers - without radio (с 01.03.1994)
540 roller blind, electric, for rear window (с 01.05.1985)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
582 air conditioner in the rear - model W140 (с 01.03.1989)
600 headlamp wiper/washer (с 01.08.1971)
613 lamp unit, asymmetrical, l.h. traffic (с 01.02.1963)
652 8-hole light alloy rims (с 01.01.1990)
668
731 wood trim, burred walnut root (с 01.08.1980)
806 Change of year of model, last figure shows new model year
883 closed aid for doors and trunk lid (с 01.07.1989)
987 battery cut-off switch for vehicles to be shipped (с 01.02.1993)
200A Unknown code
Köpråd W140 300 SE 2.8 / S 280 1996
MB 230 CE 1988 (SÅLD)
MB 500 SEC 1985 (SÅLD)
Mer information om min tidigare 500 SEC på:
http://www.garaget.org/?car=59057
Re: Köpråd W140 300 SE 2.8 / S 280 1996
Den har de gamla kablarna tyvär.
Såld ny på Barbados? Och sen importerad till kalla Sverige? Stackaren...
/John
/John
Ex MB
SLK 230K- 99
CL500 - 93
E 240 -05
SLK 230K- 99
CL500 - 93
E 240 -05
När kom dom nyare kablarna/kabelstammarna?
1997 kom de nyare kablarna.
Vilka kablar skall man byta/uppdatera "till de nya" och vad kostar dessa? Är fortfarande intresserad av dennna S 280 trots liten motor. Den har mycket utrustning inkl. kylskåp...
Jag tror en 300 SE har en betydligt enklare motorkabelstam att byta ut än t.ex. 500:an och 600:an. Kanske inte så farligt dyr på MB. Min till 600:an kostade 7600:- men Chris här på forumet var betydligt billigare.
Om du ska bygga en egen stam kan du kolla in min "Gör det själv-tråd" där du hittar länkar till mina kablar jag valde på ELFA. Hur länge de håller vet jag inte men de är iaf. värme- och kemikaliebeständiga.
Det är främst motorkabelstammen som berörs av detta (värmen). Dock gäller detta bilar som gått i vårt klimat. Har tyvärr ingen erfarenhet vad som händer med övriga "fnöskkablar" på bilar från andra breddgrader.
M116 wrote:Det är främst motorkabelstammen som berörs av detta (värmen). Dock gäller detta bilar som gått i vårt klimat. Har tyvärr ingen erfarenhet vad som händer med övriga "fnöskkablar" på bilar från andra breddgrader.
Det här problemet drabbar Mercedesmodeller i alla länder. Inte bara här i norr. Gäller samtliga MB-modeller av årgång 1991 tom 1996 enligt rykten här på nätet.
Det konstiga är att alla kablar kring motorn drabbas inte av detta.
I mitt fall har jag bytt ut kabelstammen till insprutningen, bägge ETA och LMM samt kabelstammen till oljetrycket, oljenivån och startmotorn. Övriga kablar är symtomfria.
Alla kablar är alltså inte av den nedbrytande sorten.
- Starscream
tror det är värmen som gör det..
