Samma topp på en c36a som en e320?
Här diskuterar vi alla AMG modeller och AMG relaterat.
zibpka
Seriös Hemmamekare
Seriös Hemmamekare
Postby zibpka » Thu 11 May, 2017 12:16
Letar en topp till en c36a 1996
Om man kollar artikelnummret står det att det är 1040161601
Om man kör en snabb sökning på ebay och bildelsbasen så är det samma som flera andra modeller som c280
Stämmer det eller är toppen på en c36a modifierad?
@ndreas
Re: Samma topp på en c36a som en e320?
Postby @ndreas » Sun 14 May, 2017 09:11
Hej.
Jag tror nog jag läste på nån sida om skillnaderna på topparna. AMG-toppen var portad och... äh, klistrar in infon jag hittade nu;
AMG 3.6 L M104.941
There were 3.6 L conversions done to both the M103 and M104 by Brabus, among others.
AMG developed a 3.6 L M104 that was used in the W202 C36 AMG (W202), the W124 E36 AMG (W124) and the E36 AMG (W210) vehicles.
The AMG 3.6 M104 was rated at 280 horsepower (210 kW) at 5,750 rpm and 284 pound-feet (385 N·m) of torque at 4,000 rpm using the HFM engine management system. AMG later conceded that since the engine was hand modified, power outputs could vary slightly from 276 hp to 287 hp.
The boost in displacement was obtained by boring the 2.8 litre M104 block by 2.1MM and using a highly modified version of the crankshaft from the 3.5L OM603 to increase throw by 18.9MM; this necessitated the use of new forged pistons with shorter skirts. A larger intake crossover pipe, freer flowing exhaust, a unique intake camshaft, minor changes to the cylinder head, and modifications to the HFM fuel computer also contribute to the increase in power.
Return to “AMG”
