The history of all-wheel drive models from Mercedes-Benz:
- André MBSCA
Philipp Deppe | 17.Dezember 2010
____________________________________________________________________
Over 100 years of traction to the power of four
Paul Daimler, the son of the company’s founder, came up with the first designs featuring all-wheel drive as long
ago as 1903. In 1907, the “Dernburg-Wagen”, as it was known, was produced for driving in Africa. Although built
on the basis of a truck, it was designed as a passenger car, making it the forefather of today’s cars with 4MATIC
drive. The first ever all-wheel drive passenger car from Mercedes was the W 124 E-Class model series, whose
4MATIC versions made their debut in 1985 at the IAA International Motor Show in Frankfurt.
Today’s off-roaders and SUVs have a long ancestry too. Mercedes-Benz unveiled its G 5 model in October 1938 at the London Motor Show as a “colonial and hunting
vehicle”. Alongside the G-Class, which has been powering through cross-country terrain since 1979, the G 5 is therefore the forerunner of today’s SUV models in
the form of the M-, R-, GL-Class and the GLK.
Besides this, the company also has a tradition of building commercial vehicles with off-road capabilities – from the legendary Unimog to trucks to delivery vans such
as the Vito and Sprinter.
The first all-wheel drive car for everyday use is built by the Daimler-Motoren-Gesellschaft (DMG) in 1907. The “Dernburg-Wagen”, as it is known, even features all-
wheel steering. It is designed for the then Secretary of State Bernhard Dernburg, who was to drive many kilometres in it while on colonial service in Africa the
following year. Engineer Paul Daimler, son of the company founder, uses a truck chassis from the Daimler-Motoren-Gesellschaft as the basis for the new vehicle,
which has a price tag of 34,750 Marks. It is fitted with a touring car body including two seats on the chauffeur’s bench and a total of four seats in the rear. With a
length of around 4.90 metres and a height of a good 2.70 metres including the roof structure, the majestic vehicle weighs around 3.6 tonnes when fully laden with
all the special items specified by the Colonial Office, such as a particularly heavy-duty clutch, as well as petrol and coolant reserves for tropical conditions,
replacement parts and tools.
The four-cylinder engine generates a very respectable output of 26 kW (35 hp) at 800 rpm from a displacement of about 6.8 litres – allowing a maximum speed of
around 40 km/h on level tarmac. Far more important for the vehicle however, in view of the special operating conditions, is the climbing ability made possible by
the all-wheel drive: an impressive 25 percent.
The vehicle features permanent all-wheel drive with the engine transmitting its power to the four wheels via a sophisticated mechanical system. A shaft connects it
to the transmission with four forward gears and one reverse gear that is installed exactly in the middle. From there, propshafts transfer the torque to the front and
rear axle differentials.
The design engineer Daimler takes special precautions to keep fine airborne sand out of the drive components. Because the solutions used limit the maximum
steering angle to just 23 degrees, the vehicle is equipped with steerable wheels at the rear too in order to achieve a reasonable turning circle.
A highly prestigious vehicle for off-road terrain
1934 sees the introduction of the mighty, six-wheeled G 4 passenger vehicle (W 31 model series), which is built at the Untertürkheim plant. Heads of state and high-
ranking military officers soon came to appreciate the 3.7-tonne vehicle as a highly prestigious vehicle with off-road prowess. Power is transferred to the two rigid
rear axles by a propshaft, while two locking differentials ensure good off-road capabilities (climbing ability when fully laden: 43 percent). Counting all the engine
variants, a total of 57 are made up until 1939.
The first series (1934 to 1936) is powered by a model M 24 5.0-litre eight-cylinder engine developing 74 kW (100 hp) at 3400 rpm. For the second series (1937 to
1938) the engine is enlarged to a displacement of around 5.3 litres with an output of 85 kW (115 hp), increasing again to 5.4 litres and 81 kW (110 hp) in the third
series. Although more would be feasible, the G 4 is only permitted to drive at a maximum speed of 67 km/h owing to its great weight and the limitations on tyre
stability at the time. The G 4 has an immense thirst for fuel, with figures of 28 litres per 100 kilometres on the road and 38 litres off-road. So it is little wonder that
some models are fitted with a 140-litre tank.
High-tech for passenger cars: Mercedes-Benz 4MATIC
In the mid-1980s, the time is right to introduce all-wheel drive in Mercedes-Benz passenger cars too. At the 1985 IAA International Motor Show in Frankfurt, the
engineers present their new all-wheel drive concept to the general public under the name of 4MATIC. The new system also employs electronics to provide optimum
drive power at all times in any driving situation.
The foundations for this technology were laid by the anti-lock braking system (ABS) in 1987. This provides the launch pad for the acceleration skid control system
(ASR, series production launch 1981), which is designed to control the interplay of longitudinal forces between the tyres and the road surface not only during
braking, but when accelerating too by acting on both the brakes and the engine torque. This is later followed by the automatic differential lock (ASD, 1985) and the
Electronic Stability Program (ESP, 1995).
A common feature of these systems is the way they measure wheel slip using advanced microelectronics and hydraulics, and limit it in order to improve a car’s
longitudinal dynamics. 4MATIC is permanently active and distributes the drive power between the front and rear axles during normal driving on a surface with good
traction.
4MATIC is premiered in the W 124 model series in 1987. The Electronic Traction System 4ETS, which performs the function of differential locks and ensures even
better progress on poor surfaces, is added from the 210-series E-Class onward, starting in 1997. 4ETS is integrated into the Electronic Stability Program (ESP),
whose control functions are specifically adapted for all-wheel drive. If one or more wheels lose grip on a slippery surface, 4ETS automatically applies brief braking
impulses to the individual spinning wheels while increasing drive torque to the wheels with good traction. This automatic braking intervention is able to simulate the
effect of up to three differential locks.
By the time the new 210-series E-Class comes onto the market in 1995, the technology has advanced considerably. The new 4MATIC consists of a permanent all-wheel
drive system with a single-stage transfer case providing a front-rear power split of 35:65. It is supported by the Electronic Traction System 4ETS. The new 4MATIC
system makes its debut in February 1997 in the E 280, followed in June by the E 320, with an estate version also available in both cases.
In January 2003, Mercedes-Benz presents the new 211-series E-Class at the North American International Auto Show in Detroit. From the autumn of that same year,
4MATIC all-wheel drive also becomes available for the E 240, E 320 and E 500 models, once again in both saloon and estate versions. A further distinguishing feature
of the 4MATIC models compared to the rear-wheel-drive versions is that they are exclusively available with the five-speed automatic transmission. The E 280 CDI and
E 320 CDI 4MATIC diesel models follow in July 2005. Combining 4MATIC permanent all-wheel drive with the up-to-date V6 CDI engines enables new standards to be
achieved in terms of safety, traction, pulling power and fuel economy.
Traction at its most luxurious: the S-Class 4MATIC
For the 2003 model year, Mercedes-Benz embarks on an all-wheel drive initiative for its passenger cars, making a total of 32 models available with 4MATIC in five
model series. As part of this initiative, 4MATIC is made available in the S-Class (W 220 series) during the second half of its production cycle for the S 350, S 430 and
S 500 models – including the long-wheelbase versions.
Its successor, the W 221-series S-Class, celebrates its debut in September 2005, with all-wheel drive being launched exactly one year later at the Paris Motor Show
in September 2006. For the first time ever, there is an S-Class with a diesel engine and all-wheel drive in the form of the S 320 CDI 4MATIC; it is joined by 4MATIC
versions of the S 350, S 450 and S 500, once again with a choice of either short or long wheelbase.
From March 2008, Mercedes-Benz also starts to offer the CL-Class luxury coupé (C 216) with all-wheel drive in the CL 500 4MATIC model. At its heart is the
7G-TRONIC seven-speed automatic transmission, which had been specially developed for all-wheel drive models and has a transfer case with centre differential lock
incorporated into it. It splits the drive torque between the front and rear axle in the ratio 45:55. The newly developed multi-plate clutch at the centre differential
transmits the engine’s power to all four wheels with a basic locking effect of 50 Newton metres between the front and rear axle. This results in even better start-off
characteristics and handling stability on slippery surfaces. At the same time, the all-wheel drive system is exceptionally efficient: the CL 500 4MATIC consumes no
more fuel than the corresponding rear-wheel drive model.
The 203-series C-Class also becomes available with 4MATIC as part of the 2003 all-wheel drive initiative. There is a choice of the C 240 and C 320 six-cylinder models
in either saloon or estate form.
In the summer following the Europe-wide market launch of the C-Class from the 204 model series in spring 2007, all-wheel drive becomes available in the six-
cylinder C 280, C 350 and C 320 CDI models, and from the autumn in the C 320 CDI 4MATIC Estate too. The 4MATIC system had undergone a thorough overhaul:
not only is the latest-generation all-wheel drive technology more efficient, it also weighs less and has a more compact design than the previous 4MATIC.
These benefits pay dividends in terms of lower fuel consumption and even greater traction. The all-wheel drive C-Class models are also equipped with the modified
7G-TRONIC seven-speed automatic transmission as standard.
Finally, autumn 2009 sees the launch of what is now the fourth generation of the E-Class to feature 4MATIC. The E 350 CDI BlueEFFICIENCY and E 350 (both saloon
and estate versions) as well as the E 500 saloon are the representatives of the 212 model series that are available with the permanent all-wheel drive system.
And now a very special model series is the latest to enjoy the benefits of enhanced traction: the new CLS four-door coupé will be available with 4MATIC for the first
time from 2011, with a choice of either the CLS 350 CDI BlueEFFICIENCY or CLS 500 BlueEFFICIENCY.
Off-roaders: it all starts with the Mercedes-Benz G 5
In the 1930s, Mercedes-Benz designs a variety of all-wheel drive vehicles, mainly for use by the German armed forces, although the customer was to ultimately
decide otherwise. These include the 160 HM model (W 133 II series) from 1935/36 as well as the 160 VL (1936, W 139). In 1935 the company also produces the
170 VG Kübelwagen (W 133 III series) with a selectable front-axle drive. This is followed in 1936 by the 170 VL (W 139) with permanent all-wheel drive as a
precursor to the G 5, still equipped with a 1.7-litre engine. For greater manoeuvrability, this also features selectable four-wheel steering, which reduces the turning
circle from eleven to seven metres. Roughly 100 units of these two models are delivered in total.
In technical terms, the Mercedes-Benz G 5 (W 152 series, 1937 to 1941) is the successor to the 170 VL, being also equipped with all-wheel drive and selectable all-
wheel steering. Once again the military shows little interest, and in order to expose the G 5 to a wider public, the company presents it at the London Motor Show in
October 1938 as a “colonial and hunting vehicle”. Three body versions are available ex factory: a military Kübelwagen body, a touring car with side windows and
tropical folding soft-top roof, as well as an all-purpose crew vehicle for the police, for instance. Power is provided by a four-cylinder engine with a displacement of
2.0 litres and an output of 33 kW (45 hp) at 3700 rpm. The all-wheel drive system features three differential locks. A rarity at the time, the transmission has five
forward gears, although first gear with its reduction ratio of 7.22:1 is exclusively reserved for off-road operation. The handbrake acts on the propshaft, while the
suspension is fully independent all-round. Maximum speed of the G 5 is 85 km/h, with a proviso in the operating manual not to exceed 30 km/h with the all-wheel
steering activated.
Several of these vehicles are used by the German mountain rescue services, some of them until well after the end of the Second World War. Despite the wide range
of variants and its technical perfection, the G 5 meets with little success: 378 are built in total.
Nonetheless this model may be seen as the forerunner of the privately-owned off-road vehicle, so popular nowadays. Nevertheless, it would be many years before
Mercedes-Benz included all-wheel drive passenger cars in its model range again: 1979 marks the launch of the G-Model, which has since become an outstanding
success story.
In a class of its own: the Mercedes-Benz G
The development of the Mercedes-Benz G-Model commences in 1972, when a cooperation agreement is signed between Daimler-Benz and Steyr-Daimler-Puch in
Graz, Austria. The decision to start series production of the G-Class is taken in 1975. At the same time it is decided to construct a new plant in Graz, where the
vehicle has been built mainly by hand throughout its many years of production.
In all there are four G-Class model series. The 460 (from 1979 onwards), 461 (1991) and 463 (1989) series are produced in Graz, while the 462 series is assembled
from CKD kits in Thessalonica, Greece from 1991.
Contrary to the popular view, the G-Class was neither conceived as a military vehicle, nor as a passenger car: the designers initially had their eyes on the civilian
commercial vehicle market. There is a change of direction during the concept phase, however, and the vehicle is designed instead for operation in extremely
difficult terrain. The vehicle’s backbone is a box frame with enclosed side members and cross members, ensuring exceptional flexural and torsional strength.
The frame supports robust rigid axles with large coil springs and long spring travel – a great advantage for off-road driving. With a climbing ability of up to
80 percent, a maximum tilt angle of 54 percent, 21 centimetres of ground clearance and angles of approach and departure of 36 and 27 degrees respectively,
the G-Class is equipped to negotiate the toughest off-road terrain with majestic ease. At the same time, the chassis also provides safe and comfortable handling on
smooth tarmac.
Production of the G-Class commences in Graz on 1 February 1979. Daimler-Benz provides the entire drivetrain including engine, transmission, axles and steering,
as well as the larger pressed components. Stamped and smaller pressed parts as well as the transfer case, meanwhile, are produced by Steyr-Daimler-Puch.
All versions feature a manual four-speed transmission and intermediate gearing. The all-wheel drive with additional off-road ratio is selectable, as are the 100%
differential locks on both rigid axles. The sophisticated suspension with trailing arms and wishbones, coil springs and shock absorbers makes for excellent handling
both on and off the road. Power steering is only available for the 300 GD and 280 GE as standard.
Civilian customers are able to order the G as a station wagon with a short or long wheelbase, or as a cabriolet with a short wheelbase. They come with a choice of
just five paint finishes: cream white, wheat yellow, colorado beige, carmine red and agave green. For the military there is also a long-wheelbase cabriolet with two
or four doors. In November 1980 the range is extended by a closed box-body variant with either a short or long wheelbase.
The original intention to design the G as a commercial vehicle can be seen from the list of optional extras, which includes items such as a lockable glove
compartment, power steering, halogen headlamps and a clock. Indeed, the two-spoke steering wheel and numerous switches had been taken straight from the
Mercedes-Benz commercial vehicle range. It is only the price tag of a well-equipped G-Model that indicates the direction the G would one day take with almost
visionary insight: it costs around as much as an S-Class.
The 460 series is phased out in 1991, while the plant in Graz prepares to change production over to the more up-to-date 461 series launched in 1992. This is aimed
at all those customers who attach particular importance to the technical attributes of theG-Class, and for whom the interior needs to be suited to practical use
rather than overly homely – the military, surveyors, foresters, landscape gardeners or adventure travellers, for instance. In contrast to the 463 model series with
permanent all-wheel drive, the 461 features selectable all-wheel drive with differential locks at the rear axle; these are available as an optional extra at the front.
Other standard features include a five-speed manual transmission and a 96-litre fuel tank.
The 461 series is available in three wheelbases and seven body variants. This offers an immense number of permutations, so vehicles can easily be configured for
highly specific purposes. The 461 series is eventually discontinued in 2002.
The G-Class 463 model series
In early 1987, the creators of the G-model begin to think about designing a more upmarket model series. It is christened with the number 463 and makes its debut
in 1989 at the IAA Motor Show in Frankfurt. The G-Class now comes under the aegis of the Mercedes-Benz Passenger Car Division. The move to the 463 model series
is necessary as the civilian market has become very important in the meantime and is calling for an anti-lock braking system and airbags, for example, requiring an
extensive redesign. Moreover, fewer and fewer civilian customers are smitten by the rustic charm of a simple hunting cabin on wheels – more comfort and luxury is
needed. The new generation is designed along the lines of upper mid-range passenger cars, with appointments very similar to the Mercedes-Benz saloons.
The dashboard design is adopted from the 124 model series, while fine wood trim and comfortable seats form part of the standard equipment. There is a choice of
upholsteries, including leather, as well as various colours for the interior trim, allowing the passenger compartment to be given a colour-coordinated finish.
Seating comfort in the rear is also improved. The 460 series continues to be built for customers who still prefer a rather plainer appearance.
The initially optional anti-lock braking system (ABS) makes a permanent all-wheel drive system necessary, with an inter-axle differential providing compensation
between front and rear axles. Three differential locks operated by three switches in the centre of the dashboard are also included. Activating the centre switch
automatically switches off the ABS, as the wheel brakes cannot be individually controlled in full through-drive mode.
Since 2001, the G-Class has also been equipped with the Electronic Stability Program (ESP®), 4ETS and Brake Assist, thereby offering a unique combination of highly
effective traction and handling safety systems which improve both road safety and off-road capability even further.
Since the market launch of the G-Class, a total of 200,000 vehicles have been delivered to customers worldwide.
The Sport Utility Vehicle from Mercedes-Benz: the M-Class
In 1997, Mercedes-Benz enters a fledgling market with the launch of the M-Class (W 163 series). The Sport Utility Vehicle (SUV) is equipped with 4MATIC all-wheel
drive throughout the range. The drivetrain is designed for permanent all-wheel drive from the outset. A transfer case with an integral centre differential distributes
the drive torque to the front and rear axles on a 50:50 basis. As in the other 4MATIC models from Mercedes-Benz, differential locks are replaced by the 4ETS system
in the M-Class. An anti-lock braking system is part of the standard specification; it is specially configured for off-road use and prevents the wheels from locking at
speeds above 8 km/h, whatever the state of the ground. When the low-range gearbox is activated (reduction ratio of 2.64), a special programme for speeds up to
30 km/h shortens braking distances on loose surfaces.
The M-Class is manufactured in the new plant in Tuscaloosa, Alabama, and the USA and Canada are the first markets to benefit from the new arrival in the form of
the ML 320. In March 1998, the first units are delivered to Europe, where the ML 230 is added to the range. This is followed in the same year by the ML 430 with an
eight-cylinder petrol engine. In October 1998, the torque split between the front and rear axles is changed to 48:52 to improve cornering agility on asphalt roads.
The 100,000th M-Class leaves the production line in February 1999. In May, the plant in Graz is commissioned as the second production site – particularly for the
ML 270 CDI that is extremely important for the European market – as the G-Class and the E-Class 4MATIC are already built there.
From autumn 2000, the vehicle is equipped with a new improved version of the all-wheel drive system for even greater off-road prowess. 4ETS is enhanced with new
functions that offered particular advantages on steep uphill and downhill gradients, and an actively controlled brake booster is introduced, which builds up pressure
extremely rapidly. This enables the system to brake spinning wheels even quicker than before. 4ETS meters these braking impulses according to the vehicle speed,
wheel acceleration and accelerator position.
Production of the W 163 series ends in December 2004, after total sales of around 650,000 units.
In 2005, the mantle of the 163-series M-Class is passed on to its successor, the 164 series, which is unveiled in January at the North American International
Auto Show in Detroit. Since 2001, DaimlerChrysler had already invested a total of 600 million US dollars in expanding the Tuscaloosa plant, doubling its production
capacity from 80,000 to 160,000 vehicles per year.
This increase in capacity benefits not only the M-Class, but also the R-Class that comes onto the market in the same year.
The new M-Class is launched with the very latest technology, including three powerful new engines, the 7G-TRONIC seven-speed automatic transmission as standard,
the further improved 4MATIC all-wheel drive system, AIRMATIC air suspension and (as an option) the anticipatory occupant protection system PRE-SAFE.
Mercedes-Benz had further advanced the permanent all-wheel drive and 4ETS traction system, adding additional functions such as Downhill Speed Regulation,
start-off assist and off-road ABS. There is now a choice of two all-wheel drive variants to meet the varying requirements of off-road drivers: in addition to the basic
version, a new Off-Road Pro Engineering package is available as an option, which enables the M-Class to handle even the trickiest terrain. Its primary features
include a two-speed transfer case with a low-range ratio, manually or automatically selectable differential locks (100 per cent) between the front and rear axle and
on the rear axle, plus a modified version of the AIRMATIC air suspension system which has been specially tailored to off-road driving and which raises the ground
clearance by 110 mm to as much as 291 millimetres and the vehicle’s fording depth to a maximum of 600 millimetres.
A new spatial concept on wheels: the Mercedes-Benz R-Class
New York in March 2005, where Mercedes-Benz stages a world premiere at the International Auto Show: the R-Class. Its vehicle concept blends all the advantages
of familiar vehicle categories such as a sporty saloon, estate, MPV and SUV into a new and distinctive character. Dimensions, design and dynamism are its
outstanding attributes. The R-Class is first launched on the North American market in autumn 2005, and becomes available in Europe from early 2006.
The R-Class is available in two sizes, with external lengths of 4922 and 5127 millimetres. This gives the new Mercedes-Benz model the dimensions of a luxury-class
saloon, but with a considerably more spacious interior. Standard equipment includes the 4MATIC all-wheel drive developed by Mercedes.
The second generation of the R-Class is launched in June 2010. The overall appearance benefits considerably from the completely restyled front section in
particular, and borrows elements from the Mercedes-Benz saloons and SUV models. At the same time, the latest generation offers the same level of interior diversity
for which its predecessor was renowned, and also boasts the robustness and all-wheel drive properties of the Mercedes-Benz SUVs as well as new, highly efficient
engines.
A mighty off-roader: the GL-Class
The GL-Class celebrates its world debut at the North American International Auto Show in Detroit in January 2006, and its European debut at the Geneva Motor Show
in February. As the first full-size SUV (Sport Utility Vehicle) from Mercedes-Benz, it is the highlight of the show. As a unique feature in the GL segment, this powerful
and comfortable seven-seater is equipped with a self-supporting body. The extremely robust and spacious yet lightweight construction gives the new GL-Class a
competitive edge in terms of ride comfort, dynamism and safety.
Standard specification includes 4MATIC permanent all-wheel drive. Together with the standard AIRMATIC air suspension, precise speed-sensitive power steering and
Adaptive Damping System (ADS), which likewise comes as standard, this gives the majestic GL surprisingly impressive handling. All engine variants of the GL are
paired with the 7G-TRONIC seven-speed automatic transmission as standard. Partly by virtue of its wide ratio spread, the 7G-TRONIC helps to reduce fuel
consumption in just the same way as the lightweight construction and the good aerodynamics for a vehicle of these dimensions (Cd = 0.37).
BlueTEC and all-wheel drive
Three models from Mercedes-Benz have the distinction of becoming the world’s first diesel SUVs not only to comply with the particularly stringent American BIN5
emissions standards, but also to have the potential to meet the strict EU6 emissions standards, thereby fulfilling all currently valid emissions legislation: the R 320
BlueTEC, ML 320 BlueTEC and GL 320 BlueTEC. They make their debut in June 2008, initially on the American market.
Compact model with genuine character: the GLK
The GLK receives its world premiere at the Auto China show in April 2008. Boasting a body shape that is as practical as it is arrestingly succinct, the distinctive all-
rounder was to give the market segment of compact SUVs new direction. It also harmonises what were previously seen as entirely contradictory attributes, with
supreme driving dynamics and outstanding driving safety going hand in hand with exceptional ride comfort thanks to the AGILITY CONTROL suspension.
Meanwhile the variable 4MATIC all-wheel drive system joins forces with the latest electronic control systems to deliver consummate performance on the road and
well-balanced skills off it.
___________
Brain in motion!
André MBSCA, Site Admin
Brain in motion!
