Mansory M-B SLS AMG Gets Carbon Makeover for Geneva
- André MBSCA
28 February 2011 | JClark
____________________________________________________________________
Mansory Mercedes-Benz SLS AMG Gets Carbon Makeover for Geneva
Tuesday marks the start of the 2011 Geneva Motor Show and Swiss Tuner Mansory is offering a Carbon SLS AMG
Tuesday marks the start of the 2011 Geneva Motor Show, and it wouldn’t be right to cover the show without highlighting Swiss Tuner extraordinaire Mansory’s work
on the SLS AMG. While at first glance the styling is more reminiscent of a Ferrari 599 than a Merc, we can assure you that the car in the photos is indeed the
Mercedes-Benz SLS AMG. The custom carbon Cormeum Mercedes SLS AMG will be limited to a production of a mere 15 cars, and it will offer drivers 600 HP with a
future possibility of 800 HP.
The Mansory Cormeum leaves few reminders of the Mercedes SLS AMG. The sports car manufactured in Affalterbach is only the basis for the latest development of
the automobile manufacturer Mansory Design & Holding GmbH situated in Brand near Bayreuth. 660 hp and 90 kg less weight are only two unique selling points of
this exceptional automobile which can only be obtained in a limited edition of 15 cars. At first glance, the striking design created by its owner and head designer
Kourosh Mansory can easily be discerned. Also the name was picked personally by Kourosh Mansory: An aria was already the source of his inspiration for the refined
Bugatti Veyron (Vincerò) and this time this is the aria Vide Cor meum.
In order to meet the increased requirements of the sports car when it comes to light weight and torsional stiffness, Kourosh Mansory’s team optimises almost the
entire car body and also exchanges the roof and the wing doors with ultra-light own developments. A Mansory front skirt replaces the serial bumper and due to its
well-engineered shape it reduces the uplifting forces at the front axle. Larger air inlets in connection with a new LED light unit provide the two-seater with an even
more dynamic face.
Additionally, the new front skirt supplies the enlarged cooler with more fresh air and subsequently propels the air out of the new bonnet. Mansory also replaces the
front and rear mudguards with broader newly designed light-weight parts. Therefore, the Cormeum extends by 66 millimetres at the front axle and impressive
84 millimetres at the rear axle. Mansory side skirts make the two-seater look even lower and longer and perfectly enhance the rims. The rear has also been
significantly redesigned by the aerodynamic specialists. The apron has been exchanged and a race diffuser renders additional downforce. A rear spoiler with carbon
flaps completes the aerodynamic overall package.
The extended wheel houses of the Mansory Cormeum are filled with exclusive forged wheels with central locking. They measure 9×20 inches with 265/30er tyres at
the front and 11×21 inches with 295/25er tyres at the rear axle. The tyres are provided by Mansory’s partner Michelin. Due to new springs and dampers,
the Cormeum’ s centre of gravity is 20 mm lower than the basic model and therefore additionally emphasises the exclusive rims.
The core part of the engine modification is the adjustment of high-performance compressors. Also a sports air filter and a sports exhaust system made of stainless
steel are fitted. These components are adjusted to each other with the help of a new map for engine electronics. With a top performance of 660 hp / 485 kW and
a maximum torque of 4,850 r.p.m., the Mansory engine exactly meets the wishes of its ambitious motor sports clientele.
Another performance increase up to 800 hp is already tested.
As usual, Mansory turns the interior into a highly functional control centre with unsurpassable quality and innovative design. Only most exquisite materials are used
for the interior design and therefore render a high level of comfort. The leather which is processed with masterly skill is very endurable and still extraordinarily soft.
The characteristic natural product with its special grain and the masterly perfected decorative stitches render an extravagant impression around the newly designed
centre console. Another highlight is the newly developed full size airbag sports steering wheel. The aluminium pedals and the real carbon applications complete the
luxurious overall impression of the Cormeum.
___________
Brain in motion!
André MBSCA, Site Admin
Brain in motion!
