2030 Mercedes-Benz Aria Concept - vackraste studien so far?
- André MBSCA
19 May 2011 | JClark
____________________________________________________________________
2030 Mercedes-Benz Aria Concept by Slavche Tanevski
The Mercedes-Benz Aria Concept is a vision from Slavche Tanevski developed at the Mercedes-Benz Design Studio
VIDEO: http://www.youtube.com/watch?v=HvjitrCl ... r_embedded
The Mercedes-Benz Aria Concept is a vision from Macedonian design student Slavche Tanevski developed at the Mercedes-Benz Design Studio under the supervision
of the company’s design chiefs and designers.. The Aria is an electric, luxury car for the year 2030.
It showcases a remarkable quality, with a careful design research carrie out through an incredible number of sketches and renderings.
The goal was to create a car with a timeless design that could combine a sleek silhouette with dynamic proportions and sensual, sculptural surfaces,
to express a vision of what a luxury car from Mercedes-Benz could look like in the year 2030.
As Slavche explains, “I intended to do a car with a timeless beauty. So I asked myself, what body, which products have this quality? – Musical instruments.”
“The grand piano for example, when it’s closed it looks elegant, classy, noble. When open, one sees the keyboard, the strings etc. which put the product
to another level.”
At first glance the attention is caught by the body surfaces, inspired by female body, violin, the Coke-Bottle – and supported by tensioned and articulated
lines which give the car definition and character.
A further analysis reveals a number of details, such as the distinctive “aero pins” which define the tail volume the wheels, the interior.
The main inspiration for the exterior is the flying hair. “Something very likable, spontaneous and elegant.”
Exterior Design
To express the car’s character, the front end is inspired by Alexander’s helmet, a symbol of power, leadership and with a sense of protective aesthetics.
At the same time the traditional Mercedes-Benz grille is subtly indicated.
The vehicle has wheel hub electric engines, so the air intakes are positioned on the sides instead of the center. The volumes around are dictated by the
aerodynamics.
The arrow-like traditional Benz nose is still there to change the direction of the air. The fascia form ensemble is being supported by two shovel-formed blades
which again divide the air and channel it to the E-engines and brakes respectively. In the side view, the design is characterized by the sleek trapezoidal shape.
The body is extremely stretched, with a very low greenhouse.
“The roofline is coupe-like and is subjunctively integrated in the body, for a better flow appearance.
“The character line is positioned very low and is a quotation of the Mercedes 500K Specialroadster.
“It supports the car’s stylish appearance and matches the design of the roofline, which gives homogeneousness to the overall look.
“The belt line is droplet-shaped, which underlines the aerodynamic efficiency of the car.
The front half of the shoulder edge has the opposite direction to give the car push-forward effect.
“The crisp character lines, in contrast, are connected by soft and mainly positive surfaces which show the car’s muscles.
“By avoiding too many creases and showing an interesting play of light and shadow, the surfaces articulate the reflections to achieve dynamism.”
“The radii and the direction changes on the surfaces are similar to those of a silk dress.”
Wheels design
The wheels are based on a five-spoke configuration,
which is combined with a complex surfaces that echoes the exterior form language while hinting at the electric drivetrain.
The volume is segmented to give the rim an electric feeling, to express the craft precision and to reduce weight.
The wheel is secured by copper wires, which also optically support the electrical character.
The Mercedes-Benz logo is pulled outside and has a floating impression, as it doesn’t rotate when the car moves.
Interior Design
The main characteristic of the interior is its modularity and the way it is connected to the body of the car:
it is not welded to the exterior but wired to the copper skeleton.
This makes it easily interchangeable, like home furniture. This connecting system also allows better comfort, as the wires have a flexibility that results in a second
suspension system. Inspired by a cradle, the system enables a flying sensation for the passengers.
“The design statement set with the exterior is even stronger in the interior. The flow continues inside the car as well. It’s represented by the main central metallic
frame and continues on the conjunctive seats.
“At the front the “dashboard” is formed by two piano black leafs which “levitate” over the ray-shaped structure and enhouse the steering wheel as well as
the airbags.
“The atmosphere in the cabin is very airy and roomy to give the feeling of freedom.
The concept of contrast is also used in the choice of materials: copper and aluminum used to express strength, leather and piano black surfaces as symbols of
high class and exclusivity, while the wooden floor resembles a yacht deck.
___________
Brain in motion!
André MBSCA, Site Admin
Brain in motion!
Re: 2030 Mercedes-Benz Aria Concept - vackraste studien so f
Trevligt att se stjärnan ovanpå huven i alla fall...
